Carbon-Ti Centerlock X-Rotor SteelCarbon 3
$214.99
* Unit price: $214.99 /
Article number: 007-01-02
The X-Rotor SteelCarbon 3, an evolution of the SteelCarbon 2, is a high-performance Centerlock disc. With a superlight semi-floating structure, steel braking surface, carbon fiber inner body, Al7075 Adapter, and laser-engraved titanium plate, it features Grade 5 titanium rivets and CNC-machined rounded edges meeting UCI regulations. The 1.8mm special steel track enhances braking, heat dissipation, and pad wear. Precision-crafted in Italy, it's compatible with 12, 15, or 20mm thru-axles, fits 160mm pads (preferably organic), and excelled in extreme conditions with the UAE Team Emirates during the Giro d'Italia. It's also usable as a 6-bolt rotor, showcasing precision and artisanal craftsmanship for top-tier performance.
 Fits 140 mm 160 mm 180 mm
 Total Weight ~95g ~106g ~125g
 Rotor ~68g ~80g ~98g
 Lockring Adapter ~25g
Material
 Rotor Stainless Steel / Grade 5 Titanium / Carbon Fiber
 Lockring Adapter 7075 Aluminum / Titanium
