Cane Creek Slamset Upper Headset Assembly
$43.20
Article number: 005-03-03
The Slamset from Cane Creek is designed to achieve the lowest possible stack for a headset upper without compromising the bearing seal or preload adjustment. For road cyclists desiring the most aggressive, aerodynamic riding position, or for mountain riders wanting to tip their weight balance toward the front wheel, the Slamset will be a welcome option. Each Slamset includes Cane Creek's premium Hellbender bearing for the best possible long-term durability and steering performance. Also included is a lightweight aluminum top cap and bolt assembly.
If you have any questions about these headsets please contact us or check out Cane Creeks S.H.I.S. guide to determine the proper headset for your application.
 Headset Stack Height SHIS Weight*
 IS41/28.6 4.6mm IS41/28.6/H4.6 24.5g
 IS42/28.6 4.6mm IS42/28.6/H4.6 25.5g
 ZS44/28.6 2.0mm IS44/28.6/H2 35.2g
*Weight includes upper assembly only (no top cap and bolt, no star nut)
 Top Cap and Bolt Weight          ~5.5g
