Cane Creek's line of machined aluminum seatpost shims are available to fit a wide combination of seat tubes and seatposts to easily adapt a frame to fit a smaller diameter seatpost than it was designed for. These are useful for mismatched or odd-sized frames, or for seatposts (such as Cane Creek eeSilk Suspension Seatpost) that are not available in a full size run. Each shim is expertly machined and anodized in black, with a laser etched logo and size indication. The ample length of these shims ensure maximum saftey and security at the seatpost/frame interface.
Size | Weight |
25.4 - 27.0 mm | 17 grams |
25.4 - 27.2 mm | 19 grams |
27.2 - 30.9 mm | 42 grams |
27.2 - 31.4 mm | 50 grams |
27.2 - 31.6 mm | 52 grams |
30.9 - 31.6 mm | 25 grams |
30.9 - 34.9 mm | 53 grams |
31.6 - 34.9 mm | 44 grams |
Material | machined aluminum |
Shim Length | 100 mm |
