Cane Creek Limited Edition "El Diablo" eeBrake Set
$630.00
May 2017 Update
All EE Cycleworks brakes currently in stock are then new updated 2016 models. In trying to provide the best brakeset with input from riders EE Cycleworks has once again made a rolling change to their brakes. This is a smaller update than the 2015 update and no dimensions have changes.
Centering bolt: The centering bolt has been re-enforced and the whole assembly and bolt itself is stronger.
On the fly brake adjustment: The cable tension adjuster nut is now a wing nut letting a rider reach down and adjust the cable on the fly. The interface of the adjustment nut and washer is also more shallow now. The older more concave assembly needed a lot more force to turn. The reduced force needed to adjust the the cable tension is part of EE working to make their brakes more friendly to on the fly adjustments.
2015 Update
The latest iteration of the EE Cycleworks brake expands on many of the features that have lead it to be one of the finest brakesets available. It seems unlikely that EE Cycleworks would be able to improve on the best brake on the market, but each generation of EE brakes comes stocked with a sizeable list of improvements.
Wider: The overall shape of the EE brake has been slightly altered to allow the accommodation of rims between 18 - 28 mm wide, while running up to a 28c tire.
Leverage: The leverage of the EE brake has been altered slightly to allow flawless operation on a variety of brake lever styles and brands. As always, the EE works flawlessly with Shimano levers, however Sram and Campy users can rest assured that the changes in leverage have resulted in an even playing field.
Stiffness: Each EE Brake in the most recent generation takes advantage of thinner bushings at each pivot point, which results in a further increase in stiffness. The design of the brake arm shape has been modified slightly, resulting in increased stiffness, power, and modulation. EE has continued to utilize forged brake arms that have proven to be more durable and rigid than other 100% machined brakes.
Adjustability: EE has done away with the familiar stainless steel pivot used to center the brake and replaced it with a simple mechanism that no longer requires a tool for adjustment. In order to accommodate for pad height adjustment EE Cycleworks has adopted the commonly used method of simply lengthening the brake pad slots to provide more adjustability.
The EE Brake has once again proven itself to be the yardstick by which all other brakes are measured.
Details
The EE Brake from EE Cycleworks continues to be the nicest brakeset we've ever encountered. One of the features we’ve grown to love is the design of the brake pad carrier. Changing the pad requires no special tools and only takes a few seconds. The pads are held in place using a notch and groove system, with no chance of moving under forward or backwards braking forces. However, the pad itself can be pried and slid right from the holder. This is truly a dream brake for those who switch between carbon and aluminum rims on a regular basis. Braking performance is quite impressive; on par if not exceeding the industry-leading offers from Shimano and Campagnolo. The aesthetics of the brake vary slightly from the last generation, but remain to be one of the most handsome options available. The plastic plug with the EE logo printed in front is now replaceable, and will be available in multiple colors, ensuring a proper color match for any build. The flanges around each bushing have also been done away with, allowing for a sleeker look while simultaneously using thinner bushings. The thinner bushings result in increased stiffness and therefore a better brake.
Weight, Complete 169 grams
Linkage Material 7075-T6 aluminum
Bolt Material 6/4 titanium
Reach 39-49 mm
Max Rim Width28.5 mm
Maximum Recommended Tire Size 28c
  1. Best brake ever
    Posted by Unknown
    Works as well as Dura Ace but at a fraction of the weight. Amazing.
