Cane Creek eeWings Titanium Mountain Crankset
$1,099.99
Article number: 005-02-05
The eeWings titanium crankset redefines lightweight mountain bike cranks with its fully-titanium construction, featuring 3/2.5 butted arms and a CNC-machined 6/4 spindle joined with a splined Hirth interface for strength and durability. Weighing just 400g, eeWings are lighter than most carbon cranks and offer a 20-40% stiffness increase. The 30mm spindle ensures broad compatibility, while the Hirth joint and titanium fixing bolt provide a robust connection. Available in 160-175mm lengths, the 3-bolt direct mount accommodates 1x chainrings. Cane Creek backs eeWings with a 10-year warranty.
The two-piece construction of these cranks has the spindle and non-drive crank arm as one part, and the drive side crank arm as the second part. The two are joined with a machined splined interface, secured with an oversize titanium bolt. A well-executed machined aluminum preload ring allows for easy installation and adjustment (As a bonus, this preload ring is available separately and is compatible with SRAM, Easton, and RaceFace cranksets as a replacement for the cheap plastic stock adjusters).
Compatibility
The eeWings feature a long 30mm spindle to fit a wide range of bottom bracket shell standards. See the eeWings Bottom Bracket Fitment Matrix for more information.
Compatible chainrings include those that use the SRAM-Truvativ 3-bolt direct mount. For proper chainline, 12x142 frames will require a 3mm offset chainring, while Boost 12x148 frames will require a zero offset (flat) chainring.
 Weight
 Crank ~400g
 Spider (1x - 47g) (2x - 50g)
 Chainring Mount SRAM / Truvativ 3-bolt Direct Mount style
 Drivetrain Compatibility Direct Mount - 1x only / 1x and 2x - 10, 11, and 12 Speed
