The new spiders from Cane Creek will allow direct-mount cranks to accommodate any 110 BCD 5-bolt chainring. The spiders come in two options either a 1x and 2x. allowing for greater versatility among gravel, all-road and traditional road bikes. You can order your cranks with or without the spider.
The eeWings crankset, designed and produced by American manufacturer Cane Creek, has a history that dates back over two decades. In the mid-nineties, EE Cycleworks co-founder Craig Edwards dreamed up a welded steel crankset that was (for its time) impressively light and stiff. Named the "Sweet Wings," these coveted cranksets were expensive and difficult to produce - unfortunately production died long before the hype. However, it's apparent that Craig kept his dream alive: you don't have to look too close to see that the stunning eeWings share a good share of the Sweet Wings DNA. Building on momentum from the success of their eeWings Mountain crankset, Cane Creek is now producing this All-Road version, designed for 1x drivetrains with shorter spindles and road chainlines.
For gravel, cyclocross, and any other "road bike" equipped with a 1x drivetrain, the eeWings All-Road is an elegant, high-performance option. This fully titanium crankset promises to be both light and durable, with full titanium structure that features a combination of formed, machined and welded construction, While titanium doesn't generally have the best reputation where stiffness is concerned, this carefully-engineered design is actually one of the stiffest available - with a claim of 20-40% increased stiffness over competitors' designs. At 395 grams, it's lighter than most carbon cranksets. With a brushed titanium finish with attractive heat-etched logos, this crankset is sure to draw attention.
The two-piece construction of these cranks has the spindle and non-drive crank arm as one part, and the drive side crank arm as the second part. The two are joined with a machined splined interface, secured with an oversize titanium bolt. A well-executed machined aluminum preload ring allows for easy installation and adjustment (As a bonus, this preload ring is available separately and is compatible with Sram, Easton, and RaceFace cranksets as a replacement for the cheap plastic stock adjusters).
Included is the two-piece titanium crankset and spindle assembly, titanium crank fixing bolt, titanium direct mount chainring bolts, and aluminum preload adjuster. A compatible chainring and bottom bracket must be purchased separately.
Cane Creek covers the EEWings with an impressive 10-year warranty. These will be built only in very limited quantities.
The eeWings feature a long 30mm spindle to fit a wide range of road bottom bracket shell standards, including BB30, PF30, BB86, BSA 68mm, and BB386 EVO. See the eeWings Bottom Bracket Fitment Matrix for more information.
Compatible chainrings include those that use the Sram-Truvativ 3-bolt direct mount. For proper 47mm chainline, a 6mm offset direct mount chainring is required.
The eeWings All-Road are available in three arm length options: 170, 172.5 and 175mm.
Weight, Crankarms Only | 395 grams |
Weight, Spider | 1x - 47g 2x - 50g |
Spindle Diameter | 30mm |
Q-Factor | 160mm |
Chainring Mount | SRAM/Truvativ 3-bolt Direct Mount |
Crankarm & Spindle Material | Grade 9 Ti-3Al-2.5V titanium |
Spider Material | 7075 Aluminum |
BB Shell Compatibility | BSA 68mm, BB86, BB30, PF30, BB386 EVO |
Drivetrain Compatibility | Direct Mount - 1x only 1x - 10, 11, and 12 speed 2x - 10, 11, and 12 speed |
