Cane Creek eeWings Titanium All-Road Crankset
$1,099.00
Article number: 005-03-04
The eeWings All-Road Titanium Crankset delivers top performance and durability for gravel, cyclocross, and 1x road bikes. Crafted from Grade 9 titanium, it offers 20-40% more stiffness than competitors. At 395g, it's lighter than most carbon cranksets. The two-piece design includes a spindle integrated with the non-drive arm and a separate drive-side arm, connected by a splined interface and titanium bolt. It fits various bottom bracket shells and supports 1x and 2x direct-mount setups. Available in 170, 172.5, and 175mm lengths, it comes with titanium bolts and a 10-year warranty.
The two-piece construction of these cranks has the spindle and non-drive crank arm as one part, and the drive side crank arm as the second part. The two are joined with a machined splined interface, secured with an oversize titanium bolt. A well-executed machined aluminum preload ring allows for easy installation and adjustment (As a bonus, this preload ring is available separately and is compatible with SRAM, Easton, and RaceFace cranksets as a replacement for the cheap plastic stock adjusters).
Compatibility
The spiders from Cane Creek will allow direct-mount cranks to accommodate any 110 BCD 5-bolt chainring. The spiders come in two options either a 1x and 2x, allowing for greater versatility among gravel, all-road and traditional road bikes.
The eeWings feature a long 30mm spindle to fit a wide range of road bottom bracket shell standards. See the eeWings Bottom Bracket Fitment Matrix for more information.
Compatible chainrings include those that use the SRAM-Truvativ 3-bolt direct mount. For proper 47mm chainline, a 6mm offset direct mount chainring is required.
 Weight
 Crank ~395g
 Spider (1x - 47g) (2x - 50g)
 Chainring Mount SRAM / Truvativ 3-bolt Direct Mount style
 Drivetrain Compatibility Direct Mount - 1x only / 1x and 2x - 10, 11, and 12 Speed
