Cane Creek eeSilk Suspension Seatpost - 20 mm
$319.99
Article number: 005-04-00
The eeSilk seatpost offers up to 20mm of adjustable compliance to smooth road vibrations, enhancing comfort on endurance and mixed-surface rides. Its parallel-linkage design, with forged aluminum arms and stainless steel pivots using IGUS bushings, follows the rear wheel's natural path to absorb impacts. The elastomer insert, available in five spring rates, allows customization for different rider weights. With alloy and carbon options as light as 295g and starting at $219, the eeSilk makes comfort accessible for cyclists looking to extend their rides.
  Carbon Aluminum
 Weight ~ 300g (27.2 mm) ~ 350g (27.2 mm)
 Length 350 mm 375 mm
 Min / Max Extension 70 mm / 250 mm 70 mm / 275 mm
 Material Carbon / Aluminum / Stainless Aluminum / Stainless Steel
 Offset 8 mm
 Travel 20 mm
 Rider Weight 150 - 210 lb (68-95kg) *Recommended
 Max Rider Weight 250 lbs. (113 kg.)
Elastomer Installed -- Medium
Technical Info
