Cane Creek eeSilk + Suspension Seatpost - 35 mm
Article number: | 005-04-00 |
The eeSilk seatpost adds several design improvements for increased lateral stability and now comes with two post options - alloy or carbon and an increased 35mm suspension travel. With a weight of less than 350 grams for the carbon option and a price of $219.99 for the alloy option, the eeSilk post is now a perfect fit for more riders looking to extend their ride.
Carbon | Aluminum | |
Weight | ~ 345g (27.2 mm) | ~ 385g (27.2 mm) |
Length | 350 mm | 375 mm |
Min / Max Extension | 70 mm / 250 mm | 70 mm / 275 mm |
Material | Carbon / Aluminum / Stainless | Aluminum / Stainless Steel |
Offset | 12 mm | |
Travel | 35 mm | |
Rider Weight | 150 - 210 lb (68-95kg) *Recommended | |
Max Rider Weight | 250 lbs. (113 kg.) | |
Elastomer Installed -- Medium | ||
Technical Info |
