$229.99
Article number: 005-04-00
The eeSilk Stem is a lightweight suspension stem designed to enhance comfort and reduce fatigue on gravel, endurance, and adventure bikes. It absorbs bumps and vibrations, easing strain on your hands, shoulders, and neck, so you can ride longer, faster, and more comfortably.
  • Less Fatigue = Maximum Performance
  • Compliance Switch
  • Compliance travel: Up to 20mm
  • Single Bolt Quick Change Elastomer swap
Weight 80 mm 90 mm 100 mm
  ~225g ~230g ~235g
 Clamp Diameter 31.8 mm
 Steerer Clamp Diameter 1-1/8" (28.6 mm)
 Stack Height 49 mm
 Material 7075 Aluminum
Instructions / Small Parts
