Cane Creek eeNut Expander and Top Cap
SKU:
C660A0AA
$60.00
20% SALE
The El Rosado Top Cap and eeBarKeep are 20% off.
Cane Creek's eeNut is a combination expander and top cap, two intricate and beautifully engineered components. Taking relatively simple ideas and honing them into elegant and effective components takes talent and an uncompromising drive to push limits. While the eeNut is quite fancy, the finished product is remarkably straightforward. The deeply sculpted top cap pairs perfectly with the heavily recessed expander plug. With only four individual parts, the expander appears fairly rudimentary, but the genius behind it is noteworthy. The expansion rings are captive to the tightening mechanism, eliminating the possibility of misplacing or misaligning them. The integrated height/alignment skirt ensures proper installation without measuring or worrying. This simple design allows for minimal material requirements and truly makes this cap/expander combo the best available. Paired together, the two components of the eeNut become one of the lightest options on the market, with a combined weight less than 10 grams.
The eeNut's expander is intended for use with steer tubes with an inside diameter of 22.8mm to 25mm.
Weight (Top Cap) 4.2 grams with bolt
Weight (Expander)5.3 grams
Compatibility1-1/8 Inch
Steerer Compatibility22.8mm to 25mm I.D.
Top Caps
Expanders
Aluminum
Pink (El Rosado)
Style:
Mountain
Style:
Road
