The El Rosado Top Cap and eeBarKeep are 20% off.
The frustration of a lost handlebar plug is near-universal, with almost all cyclists experiencing this feeling at some point. Beyond exposing delicate grip ends or allowing handlebar tape to unravel, a missing bar plug bares the hollow and relatively sharp handlebar end, posing a serious safety issue. The standard friction-fit plastic plugs normally supplied with bar tape can be difficult to install and often do not fit well. The eeBarKeep from Cane Creek is an elegant, lightweight, and permanent solution to the bar end problem. Using a 2-piece design with a captured o-ring and adjustable expander, this plug design allows a tight, secure fit that is incredibly easy to install using a common 4mm hex wrench. Each plug is expertly CNC machined from 6061 aluminum and tastefully finished with Cane Creek and EE etched logos. The eeBarKeep is intended to fit both drop road bars and mountain flat handlebars, with a relieved back to provide additional protection to bar tape and delicate carbon handlebar ends. Three different-sized o-ring pairs are included to allow maximum compatibility with varied handlebar inner diameters.
Sold as a pair.
Weight per plug | 6 grams |
Material | 6061 aluminum |
Sold as a pair |
