Cane Creek Direct Mount Chainring Bolt Set
$21.99
Article number: 005-03-05
The eeWings titanium chainring bolt set includes the same 3 bolt set that ships with the eeWings crankset, and will serve as an exact replacement for the factory bolts should you need a spare set.  At a mere 3 grams for the entire set, these bolts will also serve as an excellent aftermarket option for riders looking to shave a bit of extra weight off their Sram/Truvativ 3-bolt Direct Mount crankset.
 Material Titanium
 Compatibility SRAM/Truvativ 3-bolt Direct Mount
 Weight 3g (Set)
