Cane Creek Crank Preloader
$29.00
SKU:
75FC0853
When you combine Cane Creek’s manufacturing prowess with the design genius of EE Cyclework’s Craig Edwards, the result is bound to yield amazing, one-of-a-kind components.  Since joining forces in 2016, Cane Creek and EE Cycleworks have done just that, introducing updated versions of the heralded eeBrake as well as the brand new Cane Creek eeWings crankset, the eeSilk seatpost, and a handful of unique, well thought out small parts.
The Cane Creek Preload Assembly is the same assembly found on their eeWings titanium crankset, and will serve as an exact replacement for the assembly that ships with the crankset.  However, this kit will also work as a replacement preload adjuster for other 30mm spindle cranks from manufacturers such as Race Face and Sram.  This is a significant upgrade from the plastic Race Face and Sram adjusting rings; the lightweight 7075 construction is both more handsome and more durable than plastic adjusters and the Cane Creek pinch bolt has more precise tolerances and a deeper tool interface making adjustment trouble free.  This handsome preload adjuster features a gold anodized 7075 aluminum thread ring, a black anodized spacer/adjuster ring, and a grade 5 titanium 2.5mm hex fastening bolt.  Three machined extensions on the adjuster ring provide excellent control for precise adjustments, allowing ultra-fine tuning of preload.  This svelte preload solution utilizes lightweight 7075 aluminum and grade 5 titanium to keep the entire kit at just 8 grams.  Whether it be a replacement for your eeWings preload assembly, or as an upgrade for a compatible 30mm crankset, the Cane Creek Crank Preloader makes an excellent choice for a lightweight preload solution that offers ultra-fine tuning.  We will be happy to assist with any compatibility questions.
Weight8 grams
Material7075 Aluminum (Spacer Ring/Thread Ring), Grade 5 titanium (2.5mm Hex Bolt)
CompatibilityCane Creek eeWings, 30mm spindle cranks from Race Face, Sram, etc
