$15.99
Article number: 005-03-02
AER headset spacers features an interlocking design that stacks the spacers together neatly with each other. Cane Creak claims that this interlocking design allows for the spacers to act as one and eliminates any creaking noise that might occur as standard headset spacers rub together. The cut out on the sides gives the spacer unique visual appeal while reducing its weight significantly. These spacers work perfectly with any headset on the market, although they designed around and aesthetically match Cane Creek's AER Headset.
Material Aluminum Alloy
Size 1-1/8
Weight 5 mm ~ 1.9g
  10 mm  ~ 4.2g
