The premium version of Cane Creeks headset bearings, the all stainless 110 series bearings offer increased durability in harsh environments and a longer wear life compared to other manufacturers stainless bearings. With parts interchangeability between all of their headsets, these bearings are a direct replacement for any Cane Creek Headset. If you wish to upgrade your 10, 40, or AER series headsets to stainless bearings for increased durability simply pick the correct size kit and install.
Weights | |
41mm Set | 38.8 grams |
42mm Set | 40.3 grams |
41mm/52mm Set | 47.6 grams |
42mm/52mm Set | 48.1 grams |
