For riders who have lost, damaged, or just want an extra, the 110 Series aluminum crown race is lighter and more durable when compared to steel and polymer versions on the market. Compatible with every headset in Cane Creek's line, select your correct size based on the measurement of your forks crown and the outer diameter of the lower bearing.
Weights | |
47/33mm | 7.5 grams |
52/40mm | 6.5 grams |
