Cane Creek 110 Lower Headset Assembly
$39.00 - $75.00
With a best in class approach to every product they make, Cane Creek has plenty of experience producing high quality headsets and cycling components. With over four decades of knowledge to pull from their tried and true designs are able to withstand the harshest conditions. Coming into the market as Dia-Compe USA with a patent for the first thread-less headset, Cane Creek made a name for themselves with no nonsense components that performed in a wide variety of situations. With Manufacturing based here in the USA, Cane Creek is able to dream, design, prototype, and produce their components with exacting control over quality and material standards. For a company that takes pride in the quality of their product a hands on approach is essential, while many saw the return to US manufacturing as a risky move in 2008, for Cane Creek it has been an especially beneficial decision.
The 110-Series Headsets get their name from a rather specific feature that they posses. The inclusion of a 110 year Warranty shows just how confident Cane Creek is in the quality and longevity of their product. Holding a 110 Headset lets you truly appreciate the craftsmanship that goes into this premium version in Cane Creeks lineup. The Anodizing is deep and the glossy surface is polished to a nearly mirror finish. The machining is artful and only bested by the ultralight AER Headset, but the 110-Series has some unique features that greatly improve its lifespan. The double shielded bearings offer an improved lifespan in the harshest environments. The crown race has a double lip seal that seals against the inside of the frame/lower cup as well as the outer race of the bearing. For the External Cup version of the 110 Headset there is a slot machined into the inner face with an o-ring installed in it. This feature is doubly useful in keeping moisture from getting past the bearings while simultaneously holding the lower bearing in place when the fork is not there to support it. Longevity combined with easy user serviceability, and readily available replacement parts make the 110 Headset a perfect choice for any build. If you ride in harsh environments and require your equipment to last, the Cane Creek 110 is the ideal choice.
If you have any questions about this headsets please contact us or check out Cane Creeks S.H.I.S. guide to determine the proper headset for your application.
HeadsetWeightSHISStack HeightBearings
IS 47/3335.5 gramsIntegrated 47mm / 33mm Crown Race1mmBlack Oxide 45/45°
IS 52/4034.5 gramsIntegrated 52mm / 40mm Crown Race1mmStainless 36/45°
EC 44/3357 gramsExternal Cup 44mm / 33mm Crown Race12mmBlack Oxide 45/45°
EC 44/4054.5 gramsExternal Cup 44mm / 40mm Crown Race12mmStainless 36/45°
Headsets
Fits:
1-1/4 - Tapered
Fits:
1-1/8
Fits:
1-1/2 - Tapered
Style:
Mountain
Style:
Road
Aluminum
