Chain Waxing Now Offered
- Posted on
- By Chris R.
- Posted in Chain Waxing, Tech
- 0
Exploring the Benefits of Waxed Chains: Understand the Advantages, Process, and Longevity. From Independent Testing to Meticulous Cleaning, Delve into the Practicalities of Opting for Waxed Chains with Fair Wheel Bikes.
Whether you’re searching for the fastest possible drivetrain setup for your next race, or the longest-lasting chain lube to preserve the life of your chain, chainrings, and cassette, a waxed chain is probably right for you. Independent testing conducted by the speed gurus at Zero Friction Cycling has consistently shown hot-melt paraffin wax as both the fastest and longest-lasting chain lube solution on the market. What can make waxing a chain so unappealing compared to using standard lube is the cleaning process required to prepare the chain for its bath in hot wax. Whether you’re looking to get into wax for the first time or just want to reap the benefits without the labor, Fair Wheel Bikes waxed chains are the product for you.
CLEANING
- When you opt for our "Waxed chain" option, your chain goes through a meticulous ultrasonic cleaning process that employs aerospace-grade degreaser. This advanced cleaning technique ensures a thorough removal of any factory residues, dust, or contaminants that could potentially impact the chain's performance.
DRYING
- After the cleaning process, the chain is thoroughly dried to ensure that no moisture remains. Moisture can lead to corrosion, which can impact the longevity and performance of your chain.
WAXING
- Renowned for engineering excellence, Molten Speed Wax has pioneered an innovative paraffin-based chain lubrication technique fortified with friction-reducing additives to actualize class-leading efficiency. The wax matrix enables smooth articulation between chain components by minimizing interfacial resistance. While the initial waxing process takes slightly longer, it offers enduring rewards, including fluid pedaling, reduced maintenance, and prolonged chain life. Despite the patience required, the benefits of smoother rides, lower upkeep, and longer-lasting chains make it an attractive choice for optimizing cycling journeys.
CURING
- Post wax application, the chain is subjected to a curing process enabling complete wax adhesion to the chain's surfaces, resulting in a consistent and durable lubricant film.
INSPECTION
- Prior to shipment, each chain undergoes meticulous examination during the break-in process. This validation ensures uniform wax coverage and verifies impeccable condition.
REAPPLICATION INTERVAL:
- Under normal riding conditions, waxed chains maintain optimal performance for approximately 350-400 km before requiring fresh application, either via wax re-immersion or drip lube containing wax like Squirt or Silca Super Secret can be applied. The use of drip wax lube can extend the interval before re-immersion to over 1300 km. When re-immersion is due, the cleaning process is already completed, so a simple wax bath suffices to restore optimal smoothness.
Other great wax options to check out are Wend Wax and Silca Secret Chain Blend. Wend Wax-On is the first "rub-on" wax lube. You just rub the wax onto your chain's rollers for a race-ready drivetrain in seconds. Riders say it keeps chains clean and quiet while reducing friction for maximum efficiency.
Meanwhile, Silca's Secret Chain Wax Blend uses nanoparticles to penetrate deep into your chain's nooks and crannies. This creates a smooth, durable wax layer that enhances speed and efficiency over time. Pair it with Secret Chain Lube to extend your drivetrain's life by up to 10x.
Silca also makes Strip Chip - a wax-based bar that transforms factory grease into wax during hot waxing. It eliminates the need for harsh degreasers and cleans your chain in just 10 minutes.
We offer professional chain waxing exclusively for the 12 / 13 speed chains sold on fairwheelbikes.com, as well as chains sold through our physical retail shop from;
Comments
Be the first to comment...
