Bjōrn Sedlo Saddle
$300.00
Article number: 011-05-06
Meet the 'Sedlo', Bjōrn's answer to the world of full carbon saddles. When creating this saddle Bjōrn wanted to produce a carbon saddle that is comfortable enough to be used without any padding or top layer of fabric, a saddle that is comfortable, but with no unnecessary sacrifices in the weight department. Doing away with a top layer of fabric or leather allows riders to move into position easily, without issue. The cutout helps keep riders and their bibs dry, keeping long rides even more comfortable. The carbon saddle shell itself has a very slight flex, helping it dampen harsh road vibrations, while a triangular pattern on the underside of the saddle provides ample reinforcement.
  Shell Padding
 Material Carbon None
 Weight ~89g
 Length 250 mm
 Rail to Saddle Top 23 - 34 mm
 Saddle Rail 7 x 9 mm
 Rider Weight Limit 120 kg (260 lbs.)
