Bjōrn Rool Road / Gravel Handlebar
$420.00
Article number: 011-05-05
Expertly crafted for discerning cyclists seeking precise handling and comfort over long distances, the Rool carbon fiber drop bar delivers a blend of performance, durability and adaptability. Its compact geometry provides a natural hand position while the 6-degree flare allows for confident control across varied terrain. The Rool undergoes rigorous testing and over 30 design iterations to achieve the optimal balance of stiffness and compliance. With a 125mm drop and 75mm reach, it fits a wide range of riders. The bar has several fit options, we offer only the internal cable routing option for clean integration with modern groupsets.
 Hoods 38cm 40cm 42cm
 Weight ~152g ~159g ~167g
 Reach 75 mm
 Drop 125 mm
 Flare
 Stem Clamp Diameter 31.8 mm
 Material Carbon Fiber
 Finish 1k Fabric
 ICR Compatible Yes (internal ports)
 Rider Weight Limit 260 lbs (120 kg)
