Bjōrn Lapka Computer Mount
$120.00
Article number: 011-05-05
The Lapka is masterfully designed and crafted by hand in Slovenia. The mount features a single piece clamp with 1 break, which is easily installed onto a standard 31.8mm handlebar. The ring is made from multiple layers of carbon fiber, allowing the mount to be placed as close to the middle of the handlebar as possible. This mount has models available for both Garmin, and Wahoo users. In addition, the Lapka has 4 bolt holes in the mounting plate itself, allowing you to use Garmin and Wahoo inserts from a variety of manufacturers.
 Size 70 mm c-c
 Weight 17 grams
 Offset 24 mm
 Clamping Width 10 mm
 Max Load 200 grams
 Compatibility 31.8 mm Handlebar
 Material 3k Matte Carbon, Titanium
