AX Lightness Leaf Plus Carbon Saddle
$323.00
True to its name, AX Lightness' full carbon Leaf saddle is lightweight, yet wide and flat. This shape, combined with an ample cutout, provides a generous perch for riders who may be hesitant to try other notably narrow lightweight carbon saddle options. The Leaf's design allows for an inherent amount of flex, providing enough comfort and strength to be used in multiple cycling disciplines, such as road, cyclocross, and cross-country mountain biking.
The Leaf Plus is manufactured with two relieved sections on the rear of the saddle which are inlaid with thin leather pieces. The result is a flush, smooth surface very similar to the standard Leaf saddle. The leather sections add a unique, attractive look to the saddle, while adding some grip to the otherwise smooth carbon surface.
AX Lightness products are manufactured in Germany with great care and precision.
Weight~86 grams
ConstructionCarbon fiber, kevlar, leather
Width140 mm
Length265 mm
Rail Diameter8 mm round
Intended Useroad, cyclocross, cross country
Rider Weight Limit100 kg (220 lbs)
Saddles
White
Carbon
Leather
