Astral Solstice Tubeless Rim Brake Rim
Availability: | In stock (5) |
The Solstice is a light-weight rim ready to climb. These come in lighter than many carbon wheel builds, without sacrificing durability.
All Astral rims are Tubeless Easy for painless tire installation that you can set up with a pump at home.
Astral Solstice Tubeless Rim Brake Rim | |
Weight | ~405g |
Material | Aluminum |
External Rim Width | 23.5 mm |
Internal Rim Width | 20 mm |
Rim Depth | 22 mm |
Tire Compatibility | 700 x 25 |
Tubeless Compatible | Yes |
ERD | 594.5 mm |
