Astral Solstice Tubeless Rim Brake Rim
$149.00
Availability: In stock (5)
The Solstice is a light-weight rim ready to climb. These come in lighter than many carbon wheel builds, without sacrificing durability.
All Astral rims are Tubeless Easy for painless tire installation that you can set up with a pump at home.
 Weight ~405g
 Material Aluminum
 External Rim Width 23.5 mm
 Internal Rim Width 20 mm
 Rim Depth 22 mm
 Tire Compatibility 700 x 25
 Tubeless Compatible Yes
 ERD 594.5 mm
