Ashima Rite Toolz Hydraulic Fitting Press
SKU:
7792
UPC:
Default Tax Class
$31.00
Whether you’re a seasoned pro working in a world class shop, or technically well rounded home mechanic, working on hydraulic brakes without the correct tools can quickly become a nightmare. With more and more manufacturers turning to hydraulic brakes in both road and mountain applications, having a tool that precisely installs barbs in delicate hydraulic line becomes increasingly important. Luckily, Ashima has created an affordable hydraulic fitting press that is designed to withstand the rigors of everyday shop use, for years to come. Featuring 100% CNC’d alloy body, as well as a durable stainless steel barb holder, the Ashima Rite Toolz Hydraulic Fitting Press is a tool every pro mechanic should have in their toolbox. Utilizing a clever dual function design, the Ashima Hydraulic Fitting Press is capable of both prepping recently cut hydraulic line for any fitting, as well as seamless installation of each barb. Pair the Ashima Hydraulic Hose End Press with the Alligator Hose Cutter for a complete, easy to use hydraulic line tool set.
Weight146 grams
MaterialsAluminum
Stainless Steel
Hose End CompatibilityBarb, Banjo
Dimensions85 x 65 x 35 mm
General Tools
