Ashima Rite Toolz Hydraulic Fitting Press
$31.00
* Unit price: $31.00 /
Article number: 007-06-03
Ashima's Hydraulic Fitting Press is essential for precise barb installation in hydraulic lines, crucial as manufacturers shift to hydraulic brakes. Affordable and durable, it features a 100% CNC’d alloy body and stainless steel barb holder for everyday shop use. Its dual function design preps cut hydraulic lines and seamlessly installs each barb. Combine with the Alligator Hose Cutter for a comprehensive hydraulic line tool set.
 Material Aluminum / Stainless Steel
 Hose End   Compatibility Barb / Banjo
 Dimensions 85 mm x 65 mm x 35 mm
 Weight ~146g
