Ashima Disc Brake Pads
SKU:
A8C35D86
$15.00
For a high-value, high-perfomance aftermarket brake pad solution look no further than the Ashima A0107 series of pads. These pads make a great replacement option for many current Shimano, and other, flat mount brake systems (see below for compatibility). The relatively simple design of these pads forgoes extraneous features such as cooling fins, resulting in a streamlined and lightweight pad set. While coming in at only 16 grams per pair (with spring), these pads offer great accross-the-board performance. The semi-metallic compound Ashima uses for these pads works well in both cooler and more heated states, features great performance in wet and dry conditions, and is relatively slow-wearing. See below for compatibility.
•Shimano
XTR BR-M9100 ;
Dura Ace BR-R9170 ;
Ultegra BR-R8070 ;
105 BR-R7070 ;
Tiagra BR-4770 ;
GRX BR-(RX810 / RX400) ;
BR-(RS305 / RS405 / RS505 / RS805)
•Tektro
HD-(R350 / R310)
•REVER
MCX1 Flat Mount
Weight (Pads + Spring)16 grams
Material (Pads)semi-metallic
Material (Backing Plate)steel
Compatible Shimano CalipersXTR BR-M9100, Dura Ace BR-R9170, Ultegra BR-R8070, 105 BR-R7070, Tiagra BR-4770, GRX BR-(RX810 / RX400), BR-(RS305 / RS405 / RS505 / RS805)
Compatible Tektro calipersHD-(R350 / R310)
Compatible Rever calipersMCX1 Flat Mount
Disc Brakes
Brake Pads
Style:
Road Disc
Style:
Cyclocross
Fits:
Shimano
Fits:
Tektro
Fits:
Revel
Steel
