Ashima Disc Brake Adapters
$12.00
* Unit price: $12.00 /
Article number: 007-04-03
Availability: In stock (4)
Ashima disc brake adapters enable Post Mount (P.M.) caliper attachment to International Standard (I.S.) frame and fork tabs. Specify front or rear, and rotor diameter when ordering. Choose the right adapter for your setup
 Material Aluminum (Steel Bolts)
 Frame / Fork Compatibility I.S. Frame / Fork
 Caliper Compatibility PM (Post Mount) Caliper
  Compatibility Weight
 AU01 Front - 160 mm Rotor ~22g
  Rear - 140 mm Rotor
 AU02 Rear - 160 mm Rotor ~27g
 AU03 Front - 180 mm Rotor ~32g
 AU04 Rear - 180 mm Rotor ~39g
