Ashima Centerlock Adapter
$25.70
* Unit price: $25.70 /
Article number: 007-04-05
Ashima's Centerlock adapters enable the use of ISO six-bolt rotors on Shimano and DT-Swiss centerlock hubs. Expanding rotor options, the converter weighs just 26g per wheel. The primary carrier is steel, paired with aluminum components for a sturdy yet lightweight solution. To install, position the rotor, attach the assembly to the hub, and secure it with a Shimano bottom bracket tool. Tighten the threaded lockring to 40Nm for optimal stability. Upgrade your setup—Explore Ashima's Centerlock adapters now.
 Weight ~27g
 Material Steel Carrier, Aluminum Plate / Pins
 Torque 40 Nm
 Fits 9 / 10 / 12 / 15 / 20 mm Axle Hubs
 Tools Hollowtech II style BB Tool
