Ashima's Aineon disc brake uses the same stainless steel rotor as their popular Ai2 rotor with an alloy carrier. The alloy carrier can reduce weight (mostly noticeable on the larger rotors) but is mainly used by Ashima to manage heat, producing better brake performance. The six included bolts are AL-7050 and anodized with locking washers.
Material | Stainless Steel Alloy carrier |
Hub compatability | ISO 6 Bolt |
Sizes | 140mm, 160mm, 180mm |
Weights | |
140mm | 63 grams 68 grams (w/ bolts) |
180mm | 88g 95g (w/ bolts) |
160mm | 71g 78g (w/ bolts) |
