Ashima Ai2 Super Light Rotor
Article number: | 007-06-02 |
Ashima's Ai2 rotor shines as one of the lightest options. Crafted from a proprietary disc-brake steel alloy, these rotors undergo meticulous machining for precision. The unique cutout design enhances heat dissipation, ensuring reliable braking on extended descents. Experience the perfect blend of weight savings and optimal braking power with this exceptional rotor.
140 mm | 160 mm | 180 mm | |
Weight | ~64g | ~72g | ~99g |
Included | Steel Rotor Bolts (~12g) | ||
Fits | 6-bolt (ISO) | ||
Material | Stainless Steel Rotor |
