Ashima AI Stainless Steel Rotor
Article number: | 007-04-01 |
Ashima's rotors combine durability with lightweight design. Crafted from a specialized stainless steel for disc brakes, weight reduction is achieved through aggressive machining, maintaining reliability and wear life. Enlarged cut-outs serve as heat dissipation vents, and double-ground surfaces ensure rotor alignment. Compatible with standard pads, Ashima rotors offer high performance without compromising reliability.
140 mm | 160 mm | 180 mm | |
Weight | ~68g | ~85g | ~112g |
Colors | Black / Blue / Red / White | ||
Fits | 6-bolt (ISO) | ||
Material | Stainless Steel | ||
Included | Stainless Rotor Bolts (~13g) |
