$125.00
* Unit price: $125.00 /
Article number: 016-01-01
The Stelvio HS mount is the newest computer mount in the Alpitude line up. It is designed and intended to be used with THM Tibia stems, as well as Roval Rapide and Specialized SL7 bar & stem combo's. Each mount is sent with the appropriate hardware to install them to the stem/cockpit of your choice. Each mount is handmade individually, and cured at high pressures to help ensure durability.
Please contact us if you have any questions regarding compatibility
  THM Tibia Roval Rapide
 Weight ~23g ~20g
 Length 78 mm 78 mm
 Compatibility THM Tibia Roval Rapide, Specialized SL7
