Alpitude Gardena Carbon Saddle
Article number: | 016-01-02 |
The Gardena saddle is beautifully handcrafted in Trentino, Italy and features a specific cut-out and a wide front hollow section to reduce perianal pressure. Modern ergonomics and relative shortness of the saddles promotes an aggressive riding position. The Gardena Saddle is feathery light and can be used for road, gravel & cross riding. This saddle is not recommended for mountain bike riding by Alpitude and has a rider weight limit of 185 lbs. (85kg.)
Carbon Layup | UD Matte / 1k / 3k Twill / 6k | ||
Max Rider Weight Limit | 185 lbs. (85 kg) | ||
Saddle Rails | 7 x 9 | ||
Width | Nose Width | Length | Weight (±5g)* |
128 mm | 40 mm | 245 mm | ~69g |
140 mm | 45 mm | ~72g | |
150 mm | 50 mm | ~75g | |
* variation is from different layup options |
