Alligator Superior Shine 31 Strand Cable
$7.99
Cables are the unsung hero of superior bicycle performance; their function greatly affects both your mechanical shifting and braking performance. Used and poor quality cables will have a dramatically negative effect on lever feedback and derailleur performance, while good quality new cables will give the best possible performance to components of all levels. Manufacturers have attempted to improve cable performance through various designs and features, but for the most part attempts have either been too expensive (titanium cables) or have had their drawbacks (Teflon coating wearing off). In an effort to make these issues a thing of the past, Alligator has approached cable lifespan from a different angle. By re-assessing the cable manufacturing method, Alligator was able to design a stainless steel cable that simply uses more strands per cable to produce desirable characteristics, instead of utilizing exotic metals or temporary coatings. Alligator cables are each comprised of 31 individual wire strands, while typical brake or derailleur cables produced by other companies are a mere 19 strands thick. As a result of the higher strand count and an ultra-smooth drawn and polished surface, each Alligator cable is extremely slick. As an inherently low-friction cable, excellent brake and shift responsiveness can be guaranteed for the entire life of the cable.
Alligator's Superior Shine 31-strand cable is an ultra-premium die-drawn and highly polished cable designed to extract the best performance from top-tier shift and brake systems. The incredibly smooth surface of these cables means the lowest possible friction at every contact point, with no coatings to wear and degrade performance. As an alternative to their Superior Shine cable, Alligator manufactures the same basic cable in a more affordable Slick version whose production only lacks the final polishing step.
Alligator 31 Strand Cables are sold individually and available in both road brake and road/mtb shift versions, with compatibility for all modern brake and shift systems from Shimano, Sram, and Campagnolo.
CableWeight, UncutDiameterLength
Brake24 grams1.5 mm1700 mm
Shift15 grams1.1 mm2000 mm
MaterialStainless Steel
Shift Cables
Brake Cables
Silver
Fits:
Campagnolo
Fits:
Shimano
Fits:
SRAM
Stainless Steel
