With a slew of products in their lineup Alligator has been busy supplying cyclists with the components that they desire. The Stealth Rotor is Alligator’s contender in the lightweight disc brake rotor game. Constructed from SUS 410 stainless steel the ample braking surface and large vents will keep you in control in wet and dry conditions. The lightweight design removes all excess material allowing the rotor to rapidly dissipate heat even under heavy braking. Ideal for road bikes, commuting, and XC riding this rotor is the perfect way to shed a couple grams from your brakes.
Weight, 160 mm | 74 grams |
Material | 410 stainless steel |
