Alligator I-Link Brake Housing / Cable Kit
$60.00
$48.00
* Unit price: $48.00 /
Article number: 009-04-02
Availability: In stock (2)
Alligator I-Link Ultralight cable systems are 50% lighter than conventional cables, and feature a polymer liner that greatly reduces friction between the cable and housing. Ultraglide predex PTFE coated cables further reduce drag, producing a linear response during shifts. All brake cables, both Shimano / SRAM and Campagnolo, come with mountain bike brake cable ends on the other side of the cable.
All internal I-Link housing kits are set up to be used on both bikes with both cable stops and those without. A liner and end cap is provided for bikes with cable stops. A standard length of 5mm brake housing is provided for those frames without cable stops.
Compatibility Shimano, SRAM, or Campagnolo
  Internal or External Housing
Weight ~73g/set
