Alligator I-Link Brake Housing / Cable Kit
Article number: | 09-04-02 |
Alligator I-Link Ultralight cable systems are 50% lighter than conventional cables, and feature a polymer liner that greatly reduces friction between the cable and housing. Ultraglide predex PTFE coated cables further reduce drag, producing a linear response during shifts. All brake cables, both Shimano / SRAM and Campagnolo, come with mountain bike brake cable ends on the other side of the cable.
All internal I-Link housing kits are set up to be used on both bikes with both cable stops and those without. A liner and end cap is provided for bikes with cable stops. A standard length of 5mm brake housing is provided for those frames without cable stops.
Compatibility | Shimano, SRAM, or Campagnolo |
Internal or External Housing | |
Weight | ~73g/set |
