Fair Wheel Bikes Valve Core Remover
Article number: | 013-03-01 |
This simple machined aluminum tool allows for the removal of both Schraeder and Presta valve cores via the fittings on either end, with a slot in the middle for tightening and loosening common valve extenders. This tool is essential for work with tubular, tubeless, and tubed tire systems; it allows for easy filling of tire sealant, installation of valve stem extensions, and replacement of damaged valve cores.
Weight | 8.3g |
