absoluteBLACK CX1 Narrow-Wide Chainring
Article number: | 011-02-02 |
The CX chainring by absoluteBLACK is a fantastic upgrade for serious riders who desires ultimate performance and style from their chainring. absoluteBLACK uses cutting-edge 3D CAD software to CNC Machine 7075 Txxx aluminum for excellent rigidity, low weight, as well as superior wear resistance. Each absoluteBLACK chainring utilizes the Narrow-Wide tooth profile to ensure unparalleled chain retention.
Designed to fit on any 5 bolt 110 or 130 BCD crankset, the absoluteBLACK CX ring is the ideal option for those running a 1 x 9, 1 x 10, or 1 x 11 drivetrain.
The direct mount CX Narrow Wide Chainrings are designed to fit both SRAM GXP and BB30 cranks (BB30 models use 15mm spacer on drive side).
Weight | 110 BCD | 130 BCD | Direct Mount |
38t | ~57g | ~47g | |
42t | ~77g | ~64g | ~108g |
Compatibility | 5-Bolt | SRAM GXP and BB30 Cranks | |
Material | CNC Machined 7075 TXXX Aluminum |
