absoluteBLACK CX1 Narrow-Wide Chainring
$120.00
Article number: 015-01-03
The CX chainring by absoluteBLACK is a fantastic upgrade for serious riders who desires ultimate performance and style from their chainring. absoluteBLACK uses cutting-edge 3D CAD software to CNC Machine 7075 Txxx aluminum for excellent rigidity, low weight, as well as superior wear resistance. Each absoluteBLACK chainring utilizes the Narrow-Wide tooth profile to ensure unparalleled chain retention.
Designed to fit on any 5 bolt 110 or 130 BCD crankset, the absoluteBLACK CX ring is the ideal option for those running a 1 x 9, 1 x 10, or 1 x 11 drivetrain.
The direct mount CX Narrow Wide Chainrings are designed to fit both SRAM GXP and BB30 cranks (BB30 models use 15mm spacer on drive side).
 Weight 110 BCD 130 BCD Direct Mount
38t ~57g ~47g
42t ~77g ~64g ~108g
 Compatibility 5-Bolt SRAM GXP and BB30 Cranks
 Material CNC Machined 7075 TXXX Aluminum
