Absolute Black Single speed Cog
$41.99
The XX1 Singlespeed cog from Absolute Black is arguable one of the most well designed and handsome cogs available. As aesthetically pleasing as it is functional, the XX1 Singlespeed cog is designed to be tough enough to withstand many miles of abuse from even the most powerful riders. Each cog has a extra large 7mm wide base in order to prevent damage to alloy freehub bodies, which tends to be a problem for strong riders. Additionally the teeth of the cog are central to the base, which means that once your Absolute Black XX1 Singlespeed cog is worn, you have the ability to simply flip the cog over to double it’s wear life.
Similar to each chainring offered by Absolute Black, the XX1 Singlespeed cog comes equipped with the Narrow-Wide tooth profile. Each tooth of the cog is specially machined to fit with the “male” and “female” links in the chain, essentially locking the chain to the cog, resulting in the best possible fit to minimize the threat of chain drop.
The Absolute Black XX1 Singlespeed cog is compatible with any hub using a Shimano type freehub body, however we recommend each cog be installed by a competent mechanic using a torque wrench.
Hub CompatibilityShimano type freehub bodies
Drivetrain Compatibility3/32" chains
Material7075 aluminum
Weights
16 t23 grams
18 t24 grams
20 t29 grams
Cassettes
Size:
16T
Size:
18T
Size:
20T
Fits:
Single Speed
Style:
Mountain
Aluminum
Freehub Body:
Shimano Mountain
Freehub Body:
Shimano Road
