White Industries T11 Rear Hub
White Industries T11 Rear Hub 28 Hole Black Campagnolo $265.00 In Stock
White Industries T11 Rear Hub Black, 24 Hole, Campagnolo $265.00  1 Remaining
White Industries T11 Rear Hub Black, 24 Hole, Shimano $265.00  1 Remaining
White Industries T11 Rear Hub Black, 28 Hole, Shimano $265.00  1 Remaining
White Industries T11 Rear Hub Silver, 24 Hole, Shimano $265.00  1 Remaining
White Industries T11 Rear Hub Silver, 28 Hole, Shimano $265.00  1 Remaining
Weight 245 grams
Bearing Sizes 6902 (3), 6802 (2)
Axle Diameter 15 mm
Available Drillings 24, 28, 32 hole
Available Colors black, silver
Wheel Building Dimensions
Left Flange Diameter 40.5 mm
Right Flange Diameter 55.0 mm
Center to Left Flange 38.0 mm
Center to Right Flange 16.0 mm
The White Industries T11 rear hub is simply an 11 Speed upgrade to the already phenomenal H3. Given its competitively light weight, thoughtful design, quality of production and affordable price, this hub comes highly recommended for all types of cyclists. While the good folks at White Industries have succeeded in creating a competitively lightweight hub, they have done so without sacrificing performance or quality design characteristics in search of minimal weight savings.
CompatabilityThe T11 hub is fully compatible with Shimano 11 speed, 8,9 and 10 speed with the included spacer, the Campagnolo version is compatible with 9, 10 and 11 speed drivetrains.
Furthermore with the widening of the Shimano freehub body for 11 speed the hub dimensions are exactly the same between Campagnolo and Shimano. This means any conversion between the two will be a simple freehub body replacement and will not require any re-dishing.
Wheel Building
We recommend that White Industries hubs be assembled by an experienced wheel builder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on White Industries T11 Rear Hub
