White Industries T11 Front Hub
Sign Up For Our Newsletter
You're Signed Up!
Weight 90 grams
Bearing Size 6901 (2)
Axle Diameter 12 mm
Available Drillings 20, 24, 28, 32 hole
Available Colors black, silver
Wheel Building Dimensions
Flange Diameter 35.0 mm
Center to Flange 35.8 mm
Product Manuals
White Industries Front Hub Owners Manual
White Industries T11 Front Hub 20 Hole Black $134.00 In Stock
White Industries T11 Front Hub 20 Hole Silver $134.00  1 Remaining
White Industries T11 Front Hub 20 hole, Red $155.00 In Stock
White Industries T11 Front Hub 24 Hole Black $134.00 In Stock
White Industries T11 Front Hub 24 Hole Silver $134.00  1 Remaining
White Industries T11 Front Hub 24 hole, Red $155.00 In Stock
White Industries T11 Front Hub 28 Hole Black $134.00  1 Remaining
White Industries T11 Front Hub 28 Hole Silver $134.00  1 Remaining
Details
The T11 front hub is a minor functional upgrade from the already popular H2. The main differences include a small 5g weight savings and largely an aesthetic change to match the now 11 speed compatible rear T11. What does not change from the H2 is the level of craftsmanship and detail we've come to expect from White Industries hubs. The T11 features excellent design characteristics: reasonably sized flange diameters and a nice wide center to flange spacing. These critical dimensions, coupled with White's incredible finishes and affordable pricing, make them an underground favorite. The T11 hub features the same high quality Japanese cartridge bearings and a well executed bearing preload system. Each White Industries hub is individually manufactured and assembled with pride in Petaluma, California.
Wheel Building
We recommend that wheels with White Industries hubs be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on White Industries T11 Front Hub
