White Industries H3 Rear Hub
White Industries H3 Rear Hub Black, 20 Hole, Shimano$265.00  1 Remaining
White Industries H3 Rear Hub Black, 24 Hole, Campagnolo$265.00  1 Remaining
White Industries H3 Rear Hub Black, 24 Hole, Shimano$265.00  1 Remaining
White Industries H3 Rear Hub Black, 28 Hole, Campagnolo$265.00  1 Remaining
White Industries H3 Rear Hub Black, 28 Hole, Shimano$265.00 Notify Me When Available
White Industries H3 Rear Hub Black, 32 Hole, Campagnolo$265.00  1 Remaining
White Industries H3 Rear Hub Black, 32 Hole, Shimano$265.00  2 Remaining
White Industries H3 Rear Hub Silver, 24 Hole, Campagnolo$265.00  1 Remaining
White Industries H3 Rear Hub Silver, 24 Hole, Shimano$265.00  1 Remaining
White Industries H3 Rear Hub Silver, 28 Hole, Campagnolo$265.00  1 Remaining
White Industries H3 Rear Hub Silver, 28 Hole, Shimano$265.00 Notify Me When Available
White Industries H3 Rear Hub Silver, 32 Hole, Campagnolo$265.00 Notify Me When Available
White Industries H3 Rear Hub Silver, 32 Hole, Shimano$265.00  1 Remaining
Weight 249 grams
Bearing Sizes 6902 (3), 6802 (2)
Axle Diameter 15 mm
Available Drillings 24, 28, 32 hole
Available Colors black, silver
Wheel Building Dimensions
Left Flange Diameter 40.5 mm
Right Flange Diameter 55.0 mm
For Shimano Freehubs:
Center to Left Flange 36.0 mm
Center to Right Flange 18.0 mm
For Campagnolo Freehubs:
Center to Left Flange 38.0 mm
Center to Right Flange 16.0 mm
The White Industries rear hub is simply a phenomenal product. Given its competitively light weight, thoughtful design, quality of production and affordable price, this hub comes highly recommended for all types of cyclists. While the good folks at White Industries have succeeded in creating a competitively lightweight hub, they have done so without sacrificing performance or quality design characteristics in search of minimal weight savings.
The H3 is available in both Campagnolo and Shimano versions and is designed to be fully compatible with 11 speed cassettes.
Assembly
We recommend that White Industries hubs be assembled by an experienced wheel builder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on White Industries H3 Rear Hub
