White Industries CX11 Rear Hub
Sign Up For Our Newsletter
You're Signed Up!
Weight310 grams
Hub Shell Material6061 aluminum
Freehub Material6/4 titanium
Bearings (Shimano)6902 (3), 6802 (2)
Bearings (Campy)6902 (2), 6802 (4)
Wheel Building Dimensions 130 mm
Left Flange to Center35 mm
Right Flange to Center16.5 mm
Flange Diameter60 mm
Wheel Building Dimensions 135 mm
Left Flange to Center36 mm
Right Flange to Center19 mm
Product Manuals
White Industries Rear Hub Owners Manual
White Industries CX11 Rear Hub CX11 Rear Hub, Black $327.00 Notify Me When Available
Details
The CX11 rear hub is White Industries' answer to the call for a handsome 11 speed compatible disc-specific hub. With a titanium freehub body and availability in lower spoke counts, this hub is a perfect choice for those looking to build a lighter CX or disc road wheelset, without sacrificing durability. The CX11 comes in 130 mm and 135 mm spacing and both are compatible with 9 and 10 speed drivetrains as well, with the use of a simple spacer that is provided with each hub.
Ordering
The CX11 hub is sold as a special order item. When you order a hub let us know in the order comments field what spacing, drilling, and freehub body type you'd like, and please allow for an extra week in shipping. We'll contact you with details as soon as we receive your CX11 order.
Wheel Building
We recommend that wheels with White Industries hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on White Industries CX11 Rear Hub
