Vittoria Latex Tube, 700c x 19-23
In Stock
$15.00
Add to Cart:
Weight75 grams
Tire Compatibility700c x 19-23
Valve TypePresta, removeable
Valve Length51 mm
Vittoria's latex tubes feature stout construction that many of their competitors eschew for maximum weight savings. Very thin latex tubes can be fragile, making them difficult to install and more easily punctured. Vittoria latex tubes provide the best balance between weight and durability.
These latex tubes are lightly talced at the factory to improve performance and ease installation. As with any tube, care should be taken during installation to prevent pinching the tube between the tire and rim sidewall. We do not recommend the use of tire levers when installing latex tubes.
