Velocity A23 Clincher Rim
Velocity A23 Clincher Rim Black, 20 Hole$80.00 Notify Me When Available
Velocity A23 Clincher Rim Black, 24 Hole$80.00 Notify Me When Available
Velocity A23 Clincher Rim Black, 28 Hole$80.00 Notify Me When Available
Velocity A23 Clincher Rim Black, 32 Hole$80.00  2 Remaining
Velocity A23 Clincher Rim White, 20 Hole$80.00  $60.00
Save: $20.00 off
 2 Remaining
Velocity A23 Clincher Rim White, 24 Hole$80.00  $60.00
Save: $20.00 off
Velocity A23 Clincher Rim White, 28 Hole$80.00  $60.00
Save: $20.00 off
Closeout - White Rims - 25% Discount
Weight, Black440 grams
Weight, White455 grams
Width22.8 mm
Depth19.2 mm
Available Drillings20, 24, 28 hole
Tire Compatibilityclincher, 700c (ISO 622)
ERD601 mm
The design of Velocity's A23 rim is based on their popular Aerohead race rim. However, the A23 differs dramatically in the width of its sidewalls. With the bead hooks spaced 3-4 mm wider than standard road rims, tires mounted on these rims form a rounder profile. This results in lower rolling resistance combined with increased cornering control and improved aerodynamics, closely mimicing the performance benefits of tubular tires.
Assembly
We recommend that wheels built with Velocity rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
Comment on Velocity A23 Clincher Rim
