Tune Schwarzes Stuck Carbon Seatpost
Tune Schwarzes Stuck Details
Application Road, Cross Country, Cyclocross
Post Material Carbon Fiber
Clamp Material Carbon Cradle
7075 T6 Aluminum Yoke
Bolt Material Titanium TiAl6V4
Max Bolt Torque 6Nm
Rider Weight Limit 100kg MTB, Cycloross
No weight limit for road use
Clamp Range
350mm 160mm - 250mm
400mm 240mm - 330 mm
Weight
350mm 125 - 135 grams
400mm 110 - 120 grams
Tune Schwarzes Stuck Carbon Seatpost 27.2 X 350mm $390.00 Notify Me When Available
Tune Schwarzes Stuck Carbon Seatpost 27.2 X 400mm $390.00 Notify Me When Available
Tune Schwarzes Stuck Carbon Seatpost 31.6 X 350mm $390.00 Notify Me When Available
Tune Schwarzes Stuck Carbon Seatpost 31.6 X 400mm $390.00  1 Remaining
Tune Schwarzes Stuck Seatpost Details
With the Schwarzes, Tune deftly enters the ultralite seatpost category. It's only slightly heavier (10-15g in most cases) than the lightest from MCFK and Schmolke, but surpasses these other boutique brands with a highest rider weight limit for mountain bike use, and no weight limit for road. The weight savings over Tune's already popular Alloy Starkes Stuck seatpost comes through the application of carbon for the main shaft and cradle. The remainder of the post's material is a mixture of aluminum components and titanium bolts.
As with all carbon seatposts, we recommend using an assembly paste such as Tacx Dynamic Compound. Please note that a single serving of Tune-branded assembly compound is included. Use of a torque wrench is highly recommended so that the torque values do not exceed 6Nm. We recommend using slightly less torque (4-5Nm), unless the full recommended amount is necessary to prevent slippage.
Comment on Tune Schwarzes Stuck Carbon Seatpost
